Looking for opinions on whether I should sell or fix?
Old Jan 20, 2014 | 04:17 PM
  #21
brettboze's Avatar
Originally Posted by ibanez958
it is a very easy fix. drop the oil pan, make sure u clean it very good, also on the engine block side, make sure u clean where the square oil gallery to the oil pressure sensors. some of the 2.5 engine would have updated the new oil pick up too. I would not put any other addictive into the engine. Just fix it right the first time then u r problem free. but of course after that u need to change oil regularly.
I've actually already done those things, thanks though.
Old Jan 22, 2014 | 08:45 PM
  #22
oragex's Avatar
Is the oil light constantly on?
did you check rod bearing clearance with the pan off? another way to check it is pulling out spark plugs and push on the pistons
with the light on you won't get much on it, may find some guy willing to fix it
Old Jan 25, 2014 | 07:06 PM
  #23
brettboze's Avatar
It usually comes on a few minutes after driving it. Sometimes if you shut it off and back on the light will stay off for a few more minutes.
I didn't check the bearing clearance, I wish I had known to do that while I had the pan off.
Old Jan 25, 2014 | 10:56 PM
  #24
dsharp's Avatar
I went through the same thing with my wife's S60. By the time the oil light came on it had spun the #5 rod bearing.Trying to repair a problem like this with engine flush is usually a waste of time and causes more damage running all that junk through the oil pump and bearings. I bought a low mileage engine from a salvage yard for $1,000.00 and changed it out.
The engine came out the top but, it was tight.
Old Jan 26, 2014 | 07:13 PM
  #25
brettboze's Avatar
That's kind of what I was afraid of. Good to know that it is actually possible to get it out the top though.
Old Jan 26, 2014 | 08:59 PM
  #26
dsharp's Avatar
If you drop the pan look at all of the connecting rods for signs of excessive heat. The #5 rod cap was almost black. I also had to make a lifting eye for the passenger side of the motor so it would come straight up. The factory eyes let the engine roll too much. A broken seal on the oil pickup caused all of the damage.
Old Feb 2, 2014 | 03:17 PM
  #27
brettboze's Avatar
Ok will do, I think I may have taken some pictures while I had the pan off before, I might try to find those.
Old Feb 2, 2014 | 03:24 PM
  #28
brettboze's Avatar
Thanks everyone for all the information. I'm going to try to sell it as-is, if nobody wants to buy it until the engine is fixed I may try some flushes before replacing the it. I'm going to go ahead and unsubscribe from this thread, but if anyone finds it in the future please send me a message if I can offer any helpful info.
Old Feb 2, 2014 | 08:46 PM
  #29
oragex's Avatar
Depending on the amount of sludge in the oil pan, if it got into the rod bearings, they are shot.
Feel for play in the pistons (through spark plug holes).
Old Sep 9, 2014 | 03:00 AM
  #30
thehabitualcriminal's Avatar
Originally Posted by difflock54
20W50 is way to heavy an oil for Volvo engines.
Thats more likely to cause sludging.
10W 40 would be the highest i'd ever risk personally.
As for the diesel oil flushes, I shall not comment but am cringing at the thought.
Lets see what others say ??
Might as well put some diesel in the fuel tank as well, heck while your at it douse it in diesel on the 4th of July, that will make all your problems with that car go away.
mal81394
Jul 21, 2014 02:07 PM
mandobizar
Apr 17, 2013 12:42 PM
johnnypaul657
Jun 30, 2010 09:52 AM
msm15
Dec 16, 2008 08:36 PM
jktiffin
Dec 29, 2006 10:17 PM
