Low coolant light and check engine light
Old Feb 3, 2016 | 04:56 AM
brm0220's Avatar
Default Low coolant light and check engine light
Originally Posted by rspi
Hey Alex, check the coolant level before you start the engine. Not sure about your car but mine has the level sensor in the overflow tank. Make sure it's between the min and max mark, if not, add some coolant or distilled water.
You do have an old car, 10+ years so, the CEL is likely for an entirely different issue. Get that read at an auto parts store or by a mechanic to see what's going on there. How many miles do you have on the car?
Mine has the same problem . saw a small puddle on the ground near passenger side. First saw the puddle then the next day the low coolant warning came on . I added 50/50 coolant and then tonight the check engine light came on .doesn't get hot . 2000 s80 4.4L t6 with 145,000 Miles
Old Feb 7, 2016 | 08:17 PM
to the forum brm0220
Have you read the codes yet ??
How much coolant did you add ??
alexb
Jul 27, 2014 07:49 PM
Ahmed
Aug 30, 2009 01:58 PM
elderzap
Nov 7, 2007 04:58 PM
gabyman97596
Apr 22, 2007 11:10 PM
