Lower control arm DIY
Old Jun 21, 2010 | 08:44 PM
537playing's Avatar
Default Lower control arm DIY
Just got lower control arm delivered from eeuroparts.com. With that said, any advice or tips on the installation?
Old Jun 21, 2010 | 09:26 PM
dcm0123's Avatar
It will make it easier to reinstall the arm if you move the wheel spindle assembly out of the way. You will need to disconnect the tie rod end, CV shaft, brake caliper and sway bar link and possibly unhook the ABS sensor wire supports so you do not put excessive strain on the wire.
After the control arm is installed you will need to pull down on it to provide clearance to swing the wheel spindle back in place. You can do this if you put a 6X8 block of wood under the engine and run a “come along” between the two control arms and under the 6X8. Jack the control arm downwards to make clearance for the wheel spindle.
Replace the ball joint while you have it apart. Much easier to do with the control arm out of your way. Hammer a chisel between the joint flange and wheel spindle to remove it from the spindle. Apply grease to the outside of the knurled surface before putting the new one in. You will need to tap the flange on the joint with a hammer while slowly tightening the screws to install it to the control arm.
I tried to replace the control arm without moving the wheel spindle out of the way and could not line up the bolts to install the control arm to frame bolts. You also risk damaging the CV joint if you bend it at to much of an angle.
If you do as suggested, should take no more than about 3 hours.
Good luck!
Old Jun 24, 2010 | 08:32 PM
537playing's Avatar
How do I remove the CV shaft?
Old Jun 26, 2010 | 09:36 PM
dcm0123's Avatar
Only the stub shaft has to be removed from the wheel spindle. Remove the bolt which goes into the center of the shaft. When you remove the bolt, slowly push the shaft toward the engine. If needed, tap with a wooden dowel on the center of the shaft. It should move faily easy. Try to support the shaft and not put to sharp of a bend in the CV joint or you could damage it. You may have to pull outwards on the wheel spindle slighty (after you remove the ball joint, tie rod end, sway bar link and brake caliper) to have enough clearance to push the shaft clear of it.
You will have to insert the shaft before you bolt the ball joint back to the control arm.
Old Jun 27, 2010 | 05:47 PM
537playing's Avatar
Is that a 32mm size nut?
Old Jun 28, 2010 | 05:11 PM
dcm0123's Avatar
No, much smaller, I would say 15-18mm socket size.
f8talh8red
May 21, 2009 10:30 AM
etype38
Oct 13, 2008 07:50 PM
sy381
Jul 2, 2008 07:33 AM
tech
Feb 21, 2008 07:52 PM
go2sharks
Feb 25, 2007 12:08 AM
