Need a Pro: Intermittent No Crank 2008 Volvo S80 3.2 fwd
Old Jan 22, 2024 | 05:16 PM
Ryan Parker's Avatar
Default Need a Pro: Intermittent No Crank 2008 Volvo S80 3.2 fwd
Hi all. I have a 2008 Volvo S80 3.2 front wheel drive automatic. For the past 2 weeks I will get a no crank/no start while attempting to start
the car without disconnecting the positive battery terminal from the battery and reconnecting. In the cabin, all lights, audible reminders,
buttons and features are working as they should with no dimming. I put a new battery with correct specs in. I checked to make sure there
were no loose connections or corrosion at the starter and solenoid. I checked the starter relay and reseated it in the fuse box (it either works
or it doesn't I believe). I cut the positive wire from the starter by the battery terminal and got rid of the crimped terminal fuse and installed
a copper lug with no fuse for a temporary fix. There are pictures of the OEM lug with a non-reusable cover for crimped terminal wire, and the
aftermarket lug I replaced it with a temporary fix in mind (something a few people recommended to fix their cars with the same problem. It
didn't help). Rarely a "Steering Lock!" or "Immobilizer try again" or "Shift to P" message will appear after attempting to start, but it really
isn't often. It is reliable in the aspect that I can unhook the positive terminal and reattach and it will start after electronics come back on.
I am really at a loss as to what it could be, and I've spent too much time with the issue. Has anyone had a similar experience with a fix?
Old Jan 23, 2024 | 12:32 PM
I'd be looking at relays/fuses that may be in play here. Theory is, cutting the power will de-energize the relay allowing it to reset back to normal. You'd need a wiring diagram to trace through to see what can cause a no start - ie shifter position (PNP sensor?), key, antenna ring etc and see if you can pull a relay or fuse to effectively do the same thing as disconnecting the battery cable.
Old Jan 23, 2024 | 01:02 PM
Smeegle's Avatar
This video looks worthwhile trying.
robertawhite1369
Apr 25, 2022 01:01 PM
Motormed
May 5, 2020 12:02 PM
lewis s.
Dec 3, 2017 09:45 PM
Arnzillazor
Aug 9, 2016 02:27 PM
angusjustice
Apr 11, 2014 09:38 PM
