newbie, please help removing heater core
Old May 21, 2009 | 12:08 PM
redder90's Avatar
Default newbie, please help removing heater core
sup yall
been driving my 1999 s80 for 4 months now, love it
after a week of ownership i noticed a funny of
either oil or coolant coming from the vents when ever the heater was on
about 2 weeks ago started noticing that the floor on the driver side was a
little wet
figured it must have been from me due to walking across the grass
well guys, 2 days ago a big puddle appeared on the passenger side
did some research......and started to remove the heater core
I actually got the pins out, pipes pushed to the side and heater core
out half way
but, it just wont clear a little black box connected to the brake pad
believe me i searched but couldnt find reasonable release for it
and knowing me id break that little plastic thing and would end up having to tow it to the dealer
now i dont consider myself clumsy, but, im not a mechanic either
i play football for my high school but i dont think brut force is whats needed
for this issue
please help
pictures would be great
thanks alot
Old May 21, 2009 | 07:16 PM
Maybe it is hitting the brake light switch?
Those are a pain to get out without breaking them. There is 2 tabs you would have to compress to get the switch out.
Old May 22, 2009 | 07:32 AM
raygnlz's Avatar
the steering column gets in the way too. you have to drop it the column and swing it as far left as you can go to sqeeze the heater core out. its very tight in there but possible.
Old Jun 16, 2009 | 07:07 PM
redder90's Avatar
hey guys
thanks for the help
well i finally saved up enough money for a new heater core
and went to work on the car yesterday
i did managed to pull out the brake relay (with out breaking it)
but im afraid i need some more help on how to
"drop the steering column" and swing it out of the way????
thanks tech and raygnlz
something about fixin cars make a guy feel like.........a lion.
Old Jun 16, 2009 | 08:21 PM
There is 2 screws that hold it to the dash area up towards the front you have to remove the cover around the steering column. Also under the dash kind of by where the switch was there is a screw that goes like through the column and slides as well. Remove the long bolt then it will drop down some. You might also want to remove the knuckle from the floor board.
I never take any of that apart though.
ycartf
May 6, 2013 11:19 AM
jvcski
Dec 24, 2007 11:56 AM
miwachiru123
Oct 7, 2007 10:58 AM
2muchtorque
Mar 9, 2007 08:12 AM
haydenm315
Oct 18, 2006 11:08 AM
