NGK Continued - Changed Plugs today
Old Mar 30, 2008 | 12:51 PM
Capo Cam's Avatar
Default NGK Continued - Changed Plugs today
Well I took off the black plastic Volvo cover to get access to the coil packs and the plugs. After I romved the bolts the cover comes off and I see a bit of oil laying around in there? So I chock it up to left over spillage that could have been there from the many oil chages she's seen in 230k + miles. Pop off the first coil pack and remove the first plug... ::Fried::...next plug....::Fried::....Needless to say every single plug (all 6) WERE burnt out. They were NGK BKR6EIX plugs which are the eguivelent to the V-Power BKR6E plugs I replaced them with except the IX desiginates "iridium" on the NGK plugs. Back to the main concern at hand: There was oil in the first three (from drivers to passangers order) plug holes before I removed the plugs. They weren't full but there was probably a 1/4" worth of oil down there? I sucked all the oil out with a shop vac then went around the insides of the holes with shop towels to make sure they were dry before removing and replacing the plugs. Is this something I need to be concerned about? I couldn't see where any was leaking from with the car running? possibly the oil cap going bad since there was a little more oil over there on the head cover and in the hole than farther towards the passangers side? Possible overflow from oil changes or is there a gasket or seal I neeed to replace?
Thanks,
Cameron
P.S. I'm headed to Autozone to pick up a gatorback serpentine belt now. They unbelieveably had one in stock!
Old Mar 30, 2008 | 04:54 PM
jlewisinsyr's Avatar
Default RE: NGK Continued - Changed Plugs today
I'm not sure about Volvos (came from a long line of Nissans) but on Altimas the valve cover was notorious to leak and oil would leak down into the plug tubes. It was a fairly simple process to replace the valve cover seal and problem was solved.
Old Mar 30, 2008 | 06:19 PM
Bigtrev's Avatar
sounds like the oil cap seal is leaking.
Old Mar 30, 2008 | 09:27 PM
Capo Cam's Avatar
ORIGINAL: Bigtrev
That is what I am thinking but not sure? It does seem to go on without much effort at all. I wonder if I can buy just the sealing ring? I didn't look so I am not sure if it is just an o-ring or more like a gasket?
Old Mar 30, 2008 | 09:34 PM
Hey man...
You can get a filler cap gasket seperately:
http://www.trademotion.com/partlocat...layCatalogid=0
Old Mar 30, 2008 | 09:54 PM
Capo Cam's Avatar
ORIGINAL: jlewisinsyr
Hey man...
Good lookin out! Thank you!
Old Mar 30, 2008 | 10:54 PM
Ahmed's Avatar
I will be replacing my spark plugs on my 99 s80 with 132k miles very soonand would anyone recommend that I replace the coil packs and the filler cap gasket also. I have been shopping around for the coil packs online and i just cant seem to find them.
thank you
Old Mar 30, 2008 | 11:48 PM
Capo Cam's Avatar
IMO I wouldn't replace the coil packs unless you were having problems. The gasket jlewis pointed me to above for the filler cap is only like $2.17 so I will definately be replacing mine. You are probably ok unless you see oil down there like I did, but for only a couple dollars why not? Just my 2 cents
Old Apr 2, 2008 | 05:06 PM
Capo Cam's Avatar
Any ideas why all plugs were burnt? Poor maintaince or something else?
92Typhoon
Sep 11, 2020 06:09 PM
rvinson01
Dec 3, 2008 03:41 PM
Capo Cam
Mar 5, 2008 12:30 PM
swede850T
Aug 3, 2005 05:08 PM
junkmorning
Jul 3, 2005 04:16 AM
