Noise in Front End and Steering Problem
Old Jun 12, 2006 | 01:55 PM
Virginia Girl's Avatar
Default Noise in Front End and Steering Problem
HI,
I have a 2004 S80 with 70K (interstate miles). Lately, I have heard a clanking noise under the front end when I go over a rough road. Also, there is no play in my steering column but while I'm driving, I feel like I'm all over the road, like I'm swearving back and forth. Any ideas, suggestions, so forth would be appreciated. I hate to have to spend mega bucks at the dealers if I don't have to.
Thanks!
Old Jun 12, 2006 | 08:57 PM
Default RE: Noise in Front End and Steering Problem
Most common things to cause that noise.
Sway bar end links Front or Rear.
Spring Seats front.
Old Jun 13, 2006 | 09:55 AM
Thanks for the info.
Any ideas about the steering problem. Its like the tires are not steady!
Old Jun 13, 2006 | 07:48 PM
Are the tire pressures correct?
What kind of tires are on it?
It could also feel like that from the worn suspension parts.
Old Jun 14, 2006 | 10:00 AM
The Tire Pressure is ok, I have checked this.
I put new tires on Goodyear 17" about 6 months ago. Soon after that is when I began hearing the knocking sound. The steering has just become an issue within the last 2 months.
Thank you for your help!
Old Jun 14, 2006 | 10:40 AM
Check/replace those parts first.
You might also have worn Lower Control arm bushings causing the swaying.
You can have then inspected while checking the other parts.
Old Jun 14, 2006 | 10:42 AM
Thanks again for your help!
Wing0
Dec 13, 2013 02:39 PM
300K740
Dec 10, 2009 09:13 AM
francis9819
Feb 8, 2009 07:32 AM
TOm93R1
Aug 6, 2008 01:20 AM
ferraramp
Jul 20, 2007 04:38 AM
