Oil Pressure message
Old May 4, 2011 | 09:44 PM
Blue Angel's Avatar
Default Oil Pressure message
I have a 99 volvo s80, non-turbo and occassionally when my car has been running for a while and I brake a message will pop up in my computer screen that says, no oil pressure stop safetly asap and then it disappears. What do I took it to get a diagnostic check and the printout stated nothing about the oil pressure. What should I get checked?
Old May 7, 2011 | 06:34 AM
tony1963's Avatar
Your engine is filled with carbon from improper oil change frequency. Pull the pan, clean it out, reinstall along with pickup tube and o-rings.
Old May 17, 2011 | 01:10 AM
go2sharks's Avatar
bad oil sump/pan o-rings. I just had the same issue and did it on my car. Read the sticky above on Oil Sump O-rings replacement. Keep in mind, this is probably the hardest repair given the engine still on the car. the sub-frame has to be dropped way down. My advise is not to proceed without engine lift/hoist.
bydand
2001-2013 model year XC70
47
Aug 4, 2025 04:52 PM
brettboze
Mar 26, 2012 06:25 PM
Majki
Jul 22, 2010 08:22 PM
Jack
Jul 1, 2008 06:15 PM
Nuria
Apr 14, 2005 10:44 AM
