P2180 problem
Old Nov 12, 2008 | 04:58 PM
drews80's Avatar
Default P2180 problem
My check engine light just came on so i ran it and it is coming up with code P2180. Does anyone have any idea what this might be?
Old Nov 12, 2008 | 05:13 PM
Default RE: P2180 problem
Neither one of my code lists has it.
Old Nov 12, 2008 | 06:56 PM
drews80's Avatar
The car is a 2003 and after the code it said "system to rich off idle speed (bank 2)"
Old Nov 12, 2008 | 07:28 PM
spunkymonky's Avatar
Direct from VADIS for your code P2180= Volvo Code ECM-271A
Diagnostic trouble code(DTC) information
The control module receives information from the heated oxygen sensor (HO2S) about the fuel / air mixture when idling at both the lower and upper part-load range. If the fuel / air mixture deviates from A=1, the short-term fuel trim will compensate for this by adjusting the injection time so that A= 1 is achieved. When the short-term fuel trim makes an adjustment, the integrator median must be adjusted by the long-term trim. Diagnostic trouble code (DTC) ECM-271A will be stored when the long-term trim must be adjusted to almost maximum in the lower part load area.
Substitute value: None
Possible source
Upper limit:
-intake air leakage
-exhaust system air leakage
-low fuel pressure
-defective heated oxygen sensor (HO2S)
Lower limit:
-intake air leakage
-high fuel pressure
-leaking injectors
-defective mass airflow (MAP) sensor
-contaminated engine oil -oil level too high
-defective heated oxygen sensor (HO2S) Fault symptom
s70_t5_1999
Jan 22, 2010 11:53 PM
chimmychong
Apr 24, 2008 01:59 PM
volvo_s70
Jan 22, 2008 01:19 PM
toshields
Dec 8, 2007 04:50 PM
