Please Help
Old Oct 10, 2010 | 06:55 AM
Karrilee's Avatar
Default Please Help
Ok, this is getting really strange.
I turn off car, pull key out, then later on the engine fan will kick on.....I am afraid my battery is going to run down.
Why on earth would my engine fan kick on when the key is out of the car and I am not even around it?
I am getting a little worried now, so if you can please help me that would be great.
Karrilee
Old Oct 10, 2010 | 07:10 AM
Is it the fan under the hood or inside the car?
Does the temp of the car seem warmer lately?
Does it happen only after you were using the A/C in the car?
Old Oct 10, 2010 | 07:12 AM
Karrilee's Avatar
Fan under the hood and no it doesn't seem hotter, and it doesn't matter when I use the ac or not
Old Oct 10, 2010 | 07:14 AM
How long after parking the car does it usually come on?
If it is only like a few minutes then you should be fine. But if it is like 45 minutes or so then maybe the fan is going bad.
Old Oct 10, 2010 | 07:36 PM
Karrilee's Avatar
at least 30 min from just sitting there...It is kinda creepy...All of a sudden the key is out and the fan under the hood goes on....Will it run my battery down?
Old Oct 10, 2010 | 08:45 PM
It might eventually if it does not turn back off.
Old Oct 11, 2010 | 07:26 AM
Karrilee's Avatar
Any idea how much a fan will cost?
Old Oct 11, 2010 | 08:18 PM
I think it is over $300.00 but I believe you can handle it pretty easy to replace it.
Old Oct 12, 2010 | 07:54 AM
Karrilee's Avatar
Thank you for beliveing in me.
Old Oct 12, 2010 | 09:05 PM
NP it is an easy swap out.
mrlefler999
Mar 8, 2021 02:07 AM
MNWILD
Sep 10, 2020 11:29 AM
ericsb210
Mar 30, 2010 09:43 PM
Sanel30
Feb 18, 2010 09:16 PM
Epr7339
Jan 6, 2007 12:25 PM
