Regular service required message
Hi all..Just want to ask is there anyway to reset the message or make it go away?..had my maintenance done about a month ago but i guess it comes on by mileage.Thanks for the info in advance...S80..2003..2.9 non-turbo..55400 miles
Have a great one
Have a great one
Search the forum for S80 resets as there are a number of previous threads on how to do this. The short answer is 'yes', you can do a sequence of button pushes / ignition turns to reset the SERVICE indicator.
________
Buy Portable Vaporizer
________
Thanks for the info guys..PieceKeeper and Somthgfrce.
I will try to reset it acording to the sequence that you mentioned..probably won't be today..raining here and under the weather..allergies/sinus problems but thanks again..let you know if i got it done by tomorrow..have a good one
Hi guys..there is a thread about reseting the message indicator and i've tried a few times but nothing's happening...turn the key on position 1,hold the odometer down until the beep and a code came up ..045..after that the message pops up again..hope nothing major and no trip to the dealer..any comments welcome..
thanks again for the reply
Not sure about the '03 models as the sequence seems to be slightly different for each year. I've read where the '02 models have to have a non-zero value (ie: at least 0.1 miles) on the trip odometer for the reset sequence to work.
________
VAPOR
________
VAPOR
hours
Dec 26, 2014 09:37 AM
chrissygm
Sep 30, 2008 05:53 PM
almared6
Aug 3, 2007 10:36 PM
