Replacing Air mass sensor needs to reset ECU? s80 2001
Old Feb 13, 2010 | 01:51 PM
dipfrog's Avatar
Default Replacing Air mass sensor needs to reset ECU? s80 2001
Hi,
I replace air mass sensor by myself. I was wondering do I need to reset my ECU by volvo dealershop?
Old Feb 13, 2010 | 03:36 PM
Does not have to be by the dealer.
Have you cleared the codes yet?
If so then disconnect the battery for 10 minutes and that should reset the ECU settings.
Old Mar 1, 2010 | 11:21 AM
dipfrog's Avatar
Hi,
My problem was that engine idle was bouncing so I replaced a MAF sensor.
and I tried to reset my ECU settings by disconnecting the battery cable but it didn't seem to be reset. because engine idle kept bouncing.
(I was able to see some stuff were reset because the clock and radio stations were cleared)
so finally, I took my car to the dealer and they reset it with $92 charge.
I'm not so sure what the problem was.
Old Mar 1, 2010 | 05:43 PM
537playing's Avatar
After replacing the Air Mass sensor, you do not need to reset the ECU. It will correct the reading it receives from the sensor and apply the correct idling settings.
Old Mar 2, 2010 | 12:49 PM
NoLifeTilBoost's Avatar
Its a good idea to reset the ECM. This will force it to re-run its adpatation which is a good thing if you have replaced the MAF. I think its part of the Volvo dealer proceedure actually. This is different for clearing your OBD codes and requires either the ECM fuse to be removed or battery disconnected for 15mins for so. The car will run "funny" while its adapting, you can try this process to speed the adaptation up. Its taken from the 850 service manual, however the same basic principles apply:-
Originally Posted by Volvo Adaptation Process
Set parking brake, start engine in P or N. Warm up motor until it reaches normal operating temp or until the cooling fan cycles
Allow to idle for one minute in N, then select D and allow it to idle for one minute.
Accerlerate at normal hrottle position (20-50%) until vehicle shifts into top gear
Cruise at light to medium throttle
Decellerate to a stop, allowing vehicle to downshift and use brakes normally.
Av8or
Mar 25, 2013 04:57 PM
nitefamily
Jan 31, 2011 05:10 AM
luvmyv50
Feb 21, 2010 04:58 PM
mstrplmber
Aug 31, 2009 03:01 PM
jon21
Jun 22, 2007 04:34 PM
