Reversing Lights
Old Dec 13, 2007 | 03:02 AM
johnbarnewell's Avatar
Default Reversing Lights
Reversing Lights on my 1999 S80 t6 automatic have ceased functioning. Checked the fuses all are working. Probably malfunctioning switch. Can anyone indicate where the switch is positioned.
Old Dec 13, 2007 | 06:14 PM
Default RE: Reversing Lights
Most likely a bad PNP switch.
Old Dec 15, 2007 | 04:20 AM
Thank you for reply. Can you explain what is a PNP switch and where is it positioned
Old Dec 15, 2007 | 06:06 AM
The PNP switch is the park Neutral position sensor it tells the computer what gear the car is in.
It is mounted on the top of the transmission where the shifter cable attaches to the tranny.
Old Dec 19, 2007 | 09:52 AM
Thanks for help so far. I note where the cable attaches to the transmission. There is an electrical unit just beside it. Presumably this is the PNP unit
Old Dec 19, 2007 | 05:42 PM
The PNP usually mounts over the shaft the cable mounts to.
Old Dec 21, 2007 | 06:03 AM
Thanks for your continuing help. I now have gained some knowledge of the mechanics of the gear shift and cable connection to the transmission case. I have taken up the plastic housing around the gear lever and examined the arrangement there in addition I have traced the cable to the transmission case and identified where the cable moves a shaft entering the transmission case. I cannot identify any electrical unit anywhere along the run of the cable back from where it enters the transmission case at least for a number of feet whereafter it runs out of sight under the engine. I must be missing something. My first question is should I be looking near the gear lever or is PNP sensor in the region of the shaft entering the transmission case.
Old Dec 21, 2007 | 02:11 PM
Problem solved Found pictures and descriptions re replacing pnp switch on site www.volvospeed.com/Repair/pnpswitch.php
Tgnana
Apr 12, 2013 10:10 PM
rolling2
Sep 16, 2012 10:13 AM
rolling2
1998-2000 model year V70
Sep 4, 2012 11:06 AM
mavman
Aug 30, 2007 04:13 PM
gtsteve
Aug 4, 2005 12:38 AM
