Right side tail lights out
Old Feb 7, 2008 | 05:38 PM
mkelly85's Avatar
Default Right side tail lights out
I have no power to the right side tail lights (position light & brake light). I'd suspect a short somewhere, since on occasion I have power going to the outlet. I just can't find where the short is. There's power to the right inside trunk light.
Old Feb 7, 2008 | 07:50 PM
Default RE: Right side tail lights out
Look for a post from Killercam. I posted a diagram in there for the relays and fuses check the relays first.
Old Feb 8, 2008 | 12:24 AM
mkelly85's Avatar
I've seen the name before, I can find my posts, but none by this name. I can't even find the name in a general search, even though it's in this thread. I'll check all the relays tomorrow.
Old Feb 8, 2008 | 03:16 PM
Capo Cam's Avatar
Here ya go:
https://volvoforums.com/m_92593/tm.htm
Old Feb 9, 2008 | 02:42 PM
mkelly85's Avatar
Sorry, didn't work.
Old Feb 9, 2008 | 02:54 PM
Capo Cam's Avatar
I assume you already checked all the bulbs?
Old Feb 9, 2008 | 03:23 PM
mkelly85's Avatar
There isn't even power to the outlet to either the brake or positioning lights.
Old Feb 9, 2008 | 03:36 PM
Capo Cam's Avatar
ORIGINAL: mkelly85
Ah, sorry i caught that after I posted. The relay's nor diagram helped?
Old Feb 9, 2008 | 04:25 PM
mkelly85's Avatar
No...I switched the relays and there's still no power to the plugs on the right. The left side works fine.
Old Feb 9, 2008 | 06:05 PM
See if these will help at all. I tried to get everything I could.
Old Feb 13, 2008 | 06:48 PM
mkelly85's Avatar
I was about to go through the diagram when I figured I'd check all the lights again and now I realize the 3rd brake lamp is out. Somewhere I had read these bulbs get replaced with cheaper autozone lamps that cause problems with other lights. So how in the world do you get to it?
Old Feb 13, 2008 | 07:16 PM
The LEDS 3rd brake light really never burns out.
I have never seen one burn out.
You have to drop the rear of the headliner to get to it.
88740gle
Nov 13, 2015 08:13 AM
De005
Nov 18, 2009 07:58 PM
buellfire
Jun 20, 2009 12:37 AM
Scott6
Aug 13, 2008 06:12 PM
