s80 Brake Pedal Sensitivity
Old Aug 30, 2009 | 08:07 PM
jschalle's Avatar
Default s80 Brake Pedal Sensitivity
Hi all,
My 2000 S80 have very strong brakes. What is challenging is the brake pedal requires such a light amount of pressure to engage the brakes that you often apply much more brake stopping power than is needed.
Basically the first inch or two of brake pedal travel has little resistance but the brakes are being applied very strongly. There is little or no feel in the first two inches of brake pedal travel.
Any way to adjust this or might there be some type of spring missing from the pedal?
Thanks
Old Sep 13, 2009 | 05:45 PM
carlover99's Avatar
... I believe everyone is thinking what i am....... control your foot. The brakes have to be STRONG since the S80 is not a little Civic. I feel that the s80 brakes are much better compared to other vehicles of similar size.
Old Sep 13, 2009 | 07:35 PM
That is normal for the S80.
Old Sep 13, 2009 | 08:55 PM
andrei3333's Avatar
same effect here, brakes grab instantly, have new pads, rotors, fluid, brake booster, so this is as original as they get, so yeah im also convinced its the way they were designed, it does take getting used to, you will say thanks when you are traveling around 120 KM/H on the highway.
Remember the s80 weighs 3618 lbs, and has lots of power to get going, so it has to match that with enough stopping power to control all this weight. this is not a flimsy cheap sedan, this is a volvo
blackTTs80
Jul 22, 2007 05:39 PM
TheJimbo
Oct 26, 2006 11:16 PM
kaz
Jul 7, 2006 01:11 PM
arsenault
Mar 6, 2006 08:35 PM
Qamar
Aug 4, 2005 11:21 PM
