S80 CLIMATE CONTROL MODULE
My wife left the parking lights on the other day and killed the battery, my Nieghbor jumped the battery directly and now the climate control module doesn't work, any thoughts?
I have s 2000 S80 the climate control unit is not working right . The drivers side will not blow heat the **** turns to hot but no heat. So I bought another unit online and I cant even get it to work on my car. Any ideals of why my current unit will not turn to hot on the drivers side, or how can I get this replacement unit to work.
I have a 2001 V70 XC the ac was giving me problems. The climate control module was remove and put back to test if that was the problem when it was reconnected the whole panel was out including air-bags seat-warmers. Will replacing the the module repair this or will I have to have a new panel also?
There is a quick reset procedure for the module .... (give it a try)
. shut off ignition for 10 min... remove neg. battery cable for 5 min... reconnect cable
start vehicle ....move each temp control from cold to hot and back.. then fan speed to
high than back to off position (this should relearn controls)... don"t forget to relearn
the anti-theft system... close doors / un-lock doors / lock 3 times in a row
good luck ..... hope it works
thejobark
Jan 30, 2007 01:30 PM
