S80 Interior Parts?
Old Feb 29, 2008 | 06:50 PM
tenchu's Avatar
Default S80 Interior Parts?
Anyone know where I can find this and the part that is right behind it that slides back?
Also can anyone tell me what this button does? The one with the picture of a key and the back of the car on it? My trunk doesn't open with the remote or that button (which is assume is the trunk pop which is why im asking). I have to use the key to manually open it, that button is lit orange (always) on my T6
Old Feb 29, 2008 | 07:16 PM
Default RE: S80 Interior Parts?
Not sure beside the Dealer for the top part.
The switch is a valet lock out.
Meaning if you go out you give the valet the valet key with the master key you push that button and it disables the switch in the trunk to allow someone to open it.
Then when you are done with the master key you press the button again and it is off and the trunk should open.
Old Feb 29, 2008 | 07:30 PM
tenchu's Avatar
so i probobly only have the valet key?
Old Feb 29, 2008 | 08:09 PM
Does it lock the glovebox?
If it does then no its not the valet.
Also I believe the valet will not open the trunk as well.
Old Feb 29, 2008 | 10:57 PM
Ahmed's Avatar
Try this website:
vandsautodismantlers.com
They are located in California and they sell used parts from wrecked Volvos. They ship anywhere in the US.
Old Feb 29, 2008 | 11:17 PM
Capo Cam's Avatar
I NEED ONE ALSO. MY CAR HAS THE CUPHOLDER STILL ATTACHED BUT THE PREVIOUS OWNER BROKE THE LID OFF OF MINE SO I CANNOT CLOSE IT. LET ME KNOW IF / WHEN YOU FIND ON AND THE PRICE.
ORIGINAL: tech
Old Feb 29, 2008 | 11:22 PM
Capo Cam's Avatar
ORIGINAL: Ahmed
Try this website:
COOL SITE TECH, THANKS FOR THE LINK!
Old Mar 2, 2008 | 08:16 PM
silencecom's Avatar
if the light is on you cant open the trunk.. if its off then you just put your fingers under the trunk latch and it will open with no key... er maybe its the other way around.. its basicaly just a trunk lock and does the same thing as pushing the door locks button. with it locked you cant open it unless i guess you have a key hole.. i dont think mine does though.
Old Mar 2, 2008 | 09:04 PM
Capo Cam's Avatar
ORIGINAL: silencecom
On an S80 if you look just above the right side of your license plate underneath the lip (where you would grab the trunk to open it) there should be a black plug with a small cut-out on each side. if you stick your key there (or you may be able to use your fingers) and gently pry it down the plug will pop out and behind that you will find a place to stick the key in and unlock the trunk (it faces upward).
Old Mar 3, 2008 | 10:38 PM
tenchu's Avatar
Damn, that site is EXPENCIVE, $65 for the cupholder
CT_V70
Jan 18, 2010 10:00 PM
costa993
Oct 13, 2009 02:32 PM
volvos8087
Feb 20, 2009 07:17 PM
AaranRaleigh
Nov 7, 2008 12:10 AM
wufmama
Feb 20, 2006 11:44 PM
