s80 start problem
Old Nov 11, 2010 | 10:16 AM
afarmerwentworth's Avatar
Default s80 start problem
I recently bought a 99 s80 with 83k. Every once and a while when you start the car it dies and then starts on the second or third try. Once started it runs like a dream. I wonder if seafoam or some other fuel injector cleaner would help?
Old Nov 11, 2010 | 10:45 AM
gabyman97596's Avatar
Start with a tune up. Sparks, Air and fuel filter. Is the CEL on retrieve the codes. It might give you and idea where to start. But i would suggest start with the tune up.
Old Dec 8, 2010 | 04:53 PM
RogerNeedham's Avatar
Default Start problem
I havea s80 diesel 2.5 and been experiencing same at times too. I associate mine with extreme cold weather we currently have in the UK. However, when the fuel tank is above 30% filled it is not a problem. Strange but if you consider that the fuel pump and line has a return flow the fuel will take the path of least resistance. When the fuel level in the tank is high then the return flow maybe meeting resistance and offers more fuel to the injectors etc. I keep the tank level high and do not have the problem now.
DecalService
Dec 4, 2019 10:52 PM
JrDago
Sep 12, 2012 05:38 PM
MMAFIGHTER
Sep 2, 2008 08:43 PM
mehmet
May 31, 2007 01:54 PM
