S80 T6 Transmission died
Old Aug 25, 2012 | 04:01 PM
Barnacle's Avatar
Default S80 T6 Transmission died
Hi Everyone,
My car is a 99 s80 t6, with around 190,000km on it. I have owned it for the last 80,000.
The cars has been pretty reliable, although the gearbox has always had trouble keeping the torque converter locker engaged below 105kph. Below this, its always surging, trying to engage it, and a second later lets it go again.
Also at times, It has been stuck in 3rd gear when the ATF level drops. It does leak.
Well this morning while driving it, i could hear a whining noise coming from the gearbox once i started driving... whining and bubbling maybe. A short way up the road, i notice there is no drive anymore... it just revs. So i pull over and add some AFT fluid, thinking maybe its low. This gets me going... but only for about 30seconds. At the next set of lights i cant move again. I found turning off and starting lets me at least move the car.
The car is now home, and deciding whether i try tackle a rebuild myself. Any idea on what the exact cause may be? I'm studying at the moment, so I'm not made of money, but am quite capable of fixing anything myself.
Thank you for any feedback.
Nick
Old Aug 25, 2012 | 05:54 PM
akabond's Avatar
did you 1st do a search on this forum??..you might get similar symptoms from some other owners
Old Aug 25, 2012 | 07:49 PM
Barnacle's Avatar
Thanks, i have done a search, have not come up with anything to do with a complete failure.
Old Aug 26, 2012 | 05:23 PM
majorcode's Avatar
Hi Barnacle,
I am sorry to hear that. But It happened with me 3 months ago and after doing all tactics I finally had to replace the tranny. Never Go for rebuild either from the mechanic or your self...I suggest if you could do it your self...then buy the used tranny and put it into your car. It will save time and money. Good Luck.
Old Aug 27, 2012 | 10:55 PM
Barnacle's Avatar
Thanks majorcode. I have had a good run out of the car, but i was surprised the transmission gave out all of a sudden, without warning.
Might look at a used trans then... if any of them are even good! The car owes me 2000NZD and 2 front strut mount bushes.... which i only replaced a month ago! So which ever way i go, i dont have much invested in it thankfully.
Old Aug 28, 2012 | 04:28 AM
majorcode's Avatar
hahaha, Barnacle same here.....I spend only 300 USD on my first year use of Volvo with a running ok 20K KM. But all of sudden I got this transmission problem.....and spent 2000 USD. But frankly it never all of sudden if we know bad transmission symptoms...I always knew that my car don't change gear while in a cold drive....but in warm it was running smoothly...means we have keep an eye on the gear shifts. Good Luck.
stumpedbad
Aug 9, 2012 02:07 PM
anglicantraveller
Jul 7, 2010 05:30 AM
01S80T6
Mar 28, 2008 08:44 PM
MannyGoncalves
Mar 21, 2008 06:51 PM
XC90 UK
Dec 20, 2007 02:16 AM
