S80 turn signals
Old Sep 13, 2014 | 03:05 PM
heidi1916's Avatar
Default S80 turn signals
my turn signals stopped working so did the intermittent wiper, high beams and the message center\, anyone have an idea what is wrong..thanks
Old Sep 13, 2014 | 05:12 PM
damien360's Avatar
Does the horn work?
Old Sep 16, 2014 | 11:10 AM
heidi1916's Avatar
yes the horn works, but the high beams, washer fluid do not work
Old Sep 18, 2014 | 01:12 AM
orswitz's Avatar
Default fuse problem?
Did you check the fuse panel? You'll have look in your book about which location house the fuses to look for. Fuses are cheap but very hard to pull out and look at them closely to determine if they need replacement.
Old Sep 18, 2014 | 08:43 AM
heidi1916's Avatar
I found the problem, it was a plug in the steering column that came apart. Thanks for the help!!!
studd34000
Jan 9, 2007 10:01 PM
autolampsplus
Dec 18, 2006 01:42 PM
RedBrick
Sep 16, 2006 09:06 PM
WagHag
Jun 26, 2006 09:43 PM
bpeabody
Aug 2, 2004 12:16 AM
