Soft Brake Pedal - a Mystery on a 07 AWD V8
Old Jan 16, 2025 | 10:09 AM
Skidaddle07's Avatar
Default Soft Brake Pedal - a Mystery on a 07 AWD V8
Hello All,
Brand New Here!
Please feel free to let me know if I'm out of the rules lane.
I started replacing struts all around and front control arms. While apart, I put new brake pads in and had rotors resurfaced. I completed the front end and at this point when I went to turn the car around to raise the rear, I drove a short distance and the pedal is soft or spongy yet the car still stops fine. I never cracked a line; just opened the fluid reservoir to push the caliper pistons back so the new pads would fit. There are no DTC codes no ABS warning light. Am I missing something?
Any thoughts?
Old Jan 16, 2025 | 02:11 PM
did you bleed the brakes? You may need to use a power bleeder if there's some air up in the master.
Old Jan 16, 2025 | 03:45 PM
We will probably do that. Still can't figure out how air got in? Will keep an eye out for leaks
Thank you
akpasta
Feb 5, 2023 09:56 PM
Blkwidow
Apr 15, 2014 12:12 AM
stormy76
Aug 19, 2011 09:10 PM
ecberr
Oct 8, 2009 04:54 PM
rationull
Nov 11, 2008 08:42 PM
