Which Spark Plugs are best?
Old Sep 1, 2008 | 05:57 PM
Ahmed's Avatar
Default Which Spark Plugs are best?
99 s80 144k and counting.
Hello
Its about time that I get my spark plugs replaced on my car. Im just wondering which spark plug brand would be best for this car. Should I buy NGK, Bosch, Autolite double platinum(which I currently have now which were put in by the owner before me at 70K) or should I just get the original Volvo ones just to be safe. So I would like some opinons from you guys or from tech before I make a decision.
thanks
Old Sep 1, 2008 | 07:51 PM
Default RE: Which Spark Plugs are best?
Either go OEM or Bosch Platinums.
Old Sep 1, 2008 | 09:07 PM
Ahmed's Avatar
Which would you say are better. Is there a difference between the two.
Old Sep 1, 2008 | 09:15 PM
Not really any difference just preference. I use the Bosch.
Old Sep 1, 2008 | 10:05 PM
bigern45's Avatar
if your running the t6 id go with a simple copper plug. i do in mine and results are great. no spark knock or anything. gap them slightly less than what oem standards suggest. again, this is only with the turbo. they run a little cooler which is good for turbos and the smaller the gap the less chance the boost will blow out the spark...
Old Sep 5, 2008 | 07:54 PM
nicolaselias's Avatar
I use the Bosch Iridium Fusion plugs... they cost about $8 each but I guess it should be worth it...
I cant really tell too much of a difference from the oem but i assume in a t6 you may feel it more...
AlanS
Nov 22, 2010 08:16 AM
cb1313
Aug 9, 2009 07:33 AM
rooster11
Jul 19, 2009 03:03 AM
thullz
Dec 20, 2006 09:30 PM
92Typhoon
Sep 22, 2006 01:48 AM
