Steering
Old Feb 22, 2007 | 12:57 AM
gordon368's Avatar
Default Steering
I parked on some snow, it was kind of high on a hill, and anyways I went to take a left turn almost like a u-turn type turn (lol), and my steering wheel did two things it made a moaning sound that sent some vibrations to the steering wheel, as well got a little stuck... funny thing is it only did this when I took a left turn, it was so strange... It wasa smooth feeling stick though, but it happened more than 3 times, and each time it made the moaning sound...
Any Ideas?
Old Feb 22, 2007 | 08:42 PM
Default RE: Steering
Is the fluid low at all?
Is the fluid bottle broke?
Old Feb 22, 2007 | 09:52 PM
E_S80's Avatar
yeah it could be the power steering fluid, check how much is in there and look around to see if there's a leak.
Old Feb 23, 2007 | 12:43 AM
gordon368's Avatar
Oo, if its leaking, this would make it the 3rd time in the same year.... I'll have to check in the AM, thanks in advance..
Old Feb 23, 2007 | 04:22 PM
gordon368's Avatar
no fluid is 4/5ths of the way full...
Old Feb 24, 2007 | 12:31 PM
Now remove the lid again.
Look where the small hose goes into the bottle in the top back of the bottle.
Look with a flashlight. You should see a piece of plastic that goes from by the hose to the bottom of the bottle. If you look and see a copper sleeve there the bottle is bad.
Thats what is causing the noise.
Old Feb 27, 2007 | 01:38 AM
gordon368's Avatar
I looked at the top area, and the fluid itself was very blackish greeen, with little bits of glitter pieces throughout it... I couldnt find the copper sleeve though... is it near the surface of the fluid or in the middle?
Old Feb 28, 2007 | 08:59 PM
If the bottle is bad then you will be able to see it.
If you are standing on the passenger side looking in the bottle it will be far left side.
Old Feb 28, 2007 | 11:59 PM
gordon368's Avatar
Ok the noise is a lot worser, It has a scraping noise to it, and the moaning is stronger when I turn less to the left side(use to happen at the max of the turn but now a lot less turning is required), Also it felt like the tire was hitting something on the maximum part of the turning radius to the left side......
But i will check for the broken bottle tommorow.
Old Mar 1, 2007 | 04:23 PM
go2sharks's Avatar
Yup, my tire rubbed when I turn all the way left, like making a u-turn. I think the inner tie rod and bushings are bad. Like I said in the other posts, I'll get to them this summer. Since your post, I'll pay more attention not to turn all the way. It might cause the steering system to over work and go bad.
BTW, the dealer said the "inner rod has play". Of course, I'll change this too. I think it's the one causing the rubbing.
Sorry to jump in your post, but these seems to be related.
Old Mar 2, 2007 | 01:04 AM
gordon368's Avatar
interesting are these items generally covered under an exteneded warranty?
Old Mar 6, 2007 | 01:27 AM
gordon368's Avatar
I think I found the problem, that hose going to the power steering tank is leaking from there... I only saw the leak when the engine was running for a while, it was bubbling... Does the hose need to be resealed on that or change the power steering tank?
See picture
Old Mar 6, 2007 | 08:34 PM
If that clamp is tight and it keeps leaking I would replace both the hose and the bottle.
Old Mar 7, 2007 | 01:18 AM
gordon368's Avatar
I see, Tech this will make it the third time that it has leaked(it was replaced the other two times), is there possibly an underlying cause that is more serious?
Old Mar 8, 2007 | 08:36 PM
Squeeze clamp or screw clamp.
al_ngl
Nov 23, 2011 12:06 AM
2002v70
Oct 17, 2009 06:31 PM
nehopsa
Jun 24, 2008 11:20 AM
intence
Mar 3, 2008 08:40 PM
katiejoyful
Dec 12, 2007 04:49 PM
