Steering wheel vibration
Old Jul 10, 2007 | 11:30 PM
dto60's Avatar
Default Steering wheel vibration
Hi,
I have a 2000 S80 T6 that has noticable vibration in the steering wheel at highway speed (not noticable below 60mph). The vibration gets worst as the speed increases.
Wheels & tires are new and have been balanced twice and finally a third balance has been done using road force balancing (GSP9700). I still have the vibration. I also tried the winter tires and the vibration is the same.
Any ideas on other causes, tests I can perform, issues to look forwould be appreciated. Just tring to save a few dollars and avoid another visit to the shop. If that's what it takes thats OK ...
Thanks in advance,
Tom
Old Jul 12, 2007 | 12:55 PM
master_pre's Avatar
Default RE: Steering wheel vibration
It sounds like bad alignment.
Have you done a full/four tire alignment yet?
Old Jul 13, 2007 | 06:58 PM
diehardgator1's Avatar
steering wheel viberation is front tires viberation in seat is rear tires Would think tire is out of round or seperating New tire will do this Jack up front end lay a block of wood close to tire and spin tire by hand tire should not hit the block Also look at thread as tire is turning It should turn true with no wobble The rim could also be bent
floydman
Feb 11, 2010 03:22 PM
300K740
Dec 10, 2009 09:13 AM
bowes73
Jun 27, 2008 11:16 AM
ocean238
Apr 17, 2008 06:20 PM
ludeless
Nov 26, 2005 09:32 AM
