strut adjustment
Old Dec 30, 2008 | 09:35 PM
volvos8087's Avatar
Default strut adjustment
okay so i dont know if this is a problem or what i was taking a look under the hood and my driver side strut adjustment nut is at the top of the threads and passenger side is like an inch below where the threads start and obviously they are different but im wondering if i should make them the same or what and to what specs. i would much appreciate some feedback.
Old Dec 30, 2008 | 09:40 PM
andrei3333's Avatar
Default RE: strut adjustment
if i am understanding this correctly you should definitely tighten that nut,
it should be obvious, is the nut holding anything down or not ?
Old Dec 30, 2008 | 09:43 PM
volvos8087's Avatar
yes but its an adjustable strut
Old Dec 30, 2008 | 09:53 PM
andrei3333's Avatar
umm sorry you have aftermarket struts ?
S80 stock suspension is not adjustable as far as i know
Old Dec 30, 2008 | 09:56 PM
volvos8087's Avatar
i think they are im not too sure tho i just got the car
Old Dec 30, 2008 | 09:59 PM
andrei3333's Avatar
we are both gona have to wait until people with more experience on these cars chime in, i just got the car like 2 weeks ago myself
if you want take a pic and post it here , im cursious to see this myself
Old Dec 31, 2008 | 08:09 AM
tower101's Avatar
OEMs are not ajustable. The nuts should be tight, there are2 eachone with 4 "tabs" under the big washer and one one top.
Old Dec 31, 2008 | 08:14 AM
Are you talking about the big center nut or the smaller 13mm ones?
Old Dec 31, 2008 | 01:01 PM
volvos8087's Avatar
i am talking about the big center nut.
Old Dec 31, 2008 | 01:52 PM
volvos8087's Avatar
ok so i was just taking a closer look at the top nuts on the struts and i seem to be missing the top nut with therubber and washer piececuz there are two on each apparently so is this bad and where can i get one for cheap
Old Dec 31, 2008 | 02:01 PM
Anyway you can take a picture and post it?
Old Dec 31, 2008 | 02:03 PM
volvos8087's Avatar
i tried to post a pic but the file was too big it said.
Old Dec 31, 2008 | 02:18 PM
Sent PM
Old Dec 31, 2008 | 02:44 PM
Ok here is the pics you e-mailed me.
By looking at them the drivers side is normal. The passenger side has the washer it is upside down and it also looks like the cross looking nut might be missing. But hard to tell the top nut would have to be removed and then you would have to see from there.
Old Dec 31, 2008 | 02:53 PM
volvos8087's Avatar
how would i remove the nut with just a wrench or do i need another tool and is it ok to remove it?
Old Dec 31, 2008 | 02:58 PM
Im not 100 percent if it is ok to remove the car should hold the spring compressed. You can remove the nut some with a wrench or socket and see if it comes loose. Take it loose some so you can lift up the washer and see if the cross nut is under there.
If not you will need a cross nut. But I will bet it is missing.
Old Dec 31, 2008 | 03:04 PM
  #17
volvos8087's Avatar
and if it is where can i get that whole cross nut and washer thing for a decent price?
Old Dec 31, 2008 | 03:16 PM
  #18
All you will need is a nut you will not need a washer you will flip over the washer that is there.
You might have to buy it from the dealer the link below doesnt list it. You could always call them and see if they can get it.
http://www.fcpgroton.com/category-ex...168/by_year/50
Old Jan 1, 2009 | 02:07 AM
  #19
andrei3333's Avatar
try your local industrial fastener place, i work at one and we get guys coming in all the time looking for OEM automotive / truck nuts and bolts
they are just that - OEM, so what we give them is similar but not the same ... does the same job though,,,
ask for a nylon insert locking nut, grade 8 or 9 preferably - its standard if not get a regular grade 8 nut and a lock washer, or a bonded washer- take one of yours off and show it to them so they can match the threads
nhadoulis
Mar 2, 2014 10:03 PM
RJSV70
2001-2013 model year V70
Dec 6, 2012 06:10 AM
nextproject
Nov 16, 2009 07:04 PM
go2sharks
Jun 2, 2007 11:00 AM
dave_n_s
Jun 26, 2005 09:12 PM
