Sun roof
Eurka,,,, I moved the rear view mirror to the right and up. The red lettering came on the mirror. Then pushed the button for the sun roof. So it appears a loose plug or broken wire, shall investigate latter.
Not to be disrespectful but I have gone the dealer route before. I would rather poke sticks in my eyes.
Now the rearview, it's supposed to auto dim right? I see those two circles on it, I suppose they are sensors. Mine has never worked, I always did think the rearview was kind of large to not do anything special. I've read in some other posts that replacing it is the only fix, or is it? Is there a fuse I should check first?
#18
I had the same problem and I jus bought this 99' S80 from a friend, and the second day the sunroof stayed open. So I found out that if u unsnap the sunroof frame and take it out then take the interior lights out around ur mirror andn then get to the back of the mother board on that light pannel there is a lil ribbon wire that snaps into the switch. This wire comes off frequently and if u go to the dealer the stinkin switch will cost u bout $45.00 , all u do is reattach the wire and it should work.. it took me bout 30mins to get all that torn apart
hovonogila
05-16-2019 02:28 AM
