Sun Roof Problem
Old Feb 13, 2008 | 03:17 PM
HRoberts's Avatar
Default Sun Roof Problem
The sun roof in my 2000 s-80 t-6 has a problem. It jammed and I found that the two metal bars, one on the front of the glass and the one on the back of the glass fell off and caused the sun roof to jam. It looks like it was originally glue to the glass, I want to glue it back but need to know what type of glue to use. Most likely not the same type the factory used. Any help is appreciated.
Old Feb 13, 2008 | 03:59 PM
rotgut's Avatar
Default RE: Sun Roof Problem
If that is the problem, a good quality product to use is "wurth" black flexible seam sealer and adhesive, its nasty stuff to get on your hands, so get the glass out clean every thing up that gets glued, and glue it, and let it sit inside a warm area for about twentyfour hours to cure properly, also if you can find someone who sells wurth products see if they can recomend something else they have, but at the shop I work at, we use this product for a lot of things.
hovonogila
May 16, 2019 02:28 AM
850forum
Sep 30, 2008 05:43 PM
lotusing
Mar 29, 2007 03:10 AM
martyne
May 9, 2005 03:06 PM
martyne
Dec 7, 2004 09:58 PM
