Sunroof Glass Broke - Help Replacing
Old Aug 3, 2009 | 11:09 AM
cbm3384's Avatar
Default Sunroof Glass Broke - Help Replacing
As the title says, my sunroof glass shattered with the sunroof in the open position. I first of all need some instruction on how to replace it, where to find glass that is reasonably priced rather than pay the dealer $500, and finally figure out how to get the sunroof to close. It is currently stuck about 1/3 closed and it won't go any further. I have cleaned out as much glass as I can from the area so I am not sure what the issue is at this point. Any advice is greatly appreciated!
Old Aug 3, 2009 | 07:59 PM
Did it break from being jammed?
There is 2 screws on each side that hold the metal framing for the sunroof. They are under the plastic organ looking things.
Check Erie volvo for a used one.
Old Aug 4, 2009 | 05:23 AM
vegasjetskier's Avatar
www.erievovo.com or www.vandsautodismantlers.com
Old Aug 4, 2009 | 11:19 PM
matt14's Avatar
There may be some glass stuck in the sunroof pan, and causing the rails to bind. Its hard to get the glass out, and if there is some stuck in there, that meens the sunroof needs to come out replace the guide rails need to be cleaned.
naelec
Apr 14, 2011 03:01 PM
KitKat40
Sep 23, 2010 02:02 PM
hurleyman52
Apr 29, 2010 01:07 AM
cruiserguy
Jul 2, 2009 05:29 AM
msf7770
Jan 30, 2007 05:30 PM
