Swishing Sounds
Old Sep 26, 2009 | 10:10 AM
537playing's Avatar
Default Swishing Sounds
With my AC running, once in a while I'll hear a SWISHING sound somewhere within the dash. It only happens with the AC and not the heat.
Am I low on Freon????? Can I DIY add Freon??
2001 S80 2.9L 114,000miles
Old Sep 26, 2009 | 11:36 AM
N_Vagrant's Avatar
sounds like the AC isn't draining properly, there's just a backage somewhere, and there's water sloshin' around your dash, is it coming from the passenger side? My mom's RX-8 with 30k has the same problem right now lol.
Old Sep 26, 2009 | 05:51 PM
537playing's Avatar
It doesn't sound like a fluid sound but rather an air sound. Keep in mind that the sound occurs both driving and sitting still eliminating outside wind causing this sound.
Old Sep 26, 2009 | 06:13 PM
It will make a little noise. If it the freon slowing and going faster as the compressor cycles on and off.
Old Sep 26, 2009 | 06:36 PM
Lyonsroar's Avatar
Your mom drives an RX-8?
Sweet mom.
Sorry, off topic!
Old Sep 27, 2009 | 07:10 PM
diehardgator1's Avatar
Mine makes the same noise sounds like air hissing coming out of the dash you can turn the air off and it will stop. Have been told it was in the in line check valve or stem some call it.
Old Sep 27, 2009 | 07:14 PM
Expansion valve?
Old Sep 27, 2009 | 08:10 PM
yes i think that is what they called it Been doing for 2 years now cools great gonna leave well enough along
Old Sep 27, 2009 | 08:22 PM
It is pretty much the same expansion valve block that Chrysler used in the 80's.
Old Sep 27, 2009 | 08:56 PM
537playing's Avatar
Any solution?
Old Sep 27, 2009 | 09:01 PM
Replacing the expansion block.
ENDEE666
Jan 13, 2008 07:25 PM
Richard74
May 14, 2006 03:29 PM
vqmaxi17
Jan 17, 2006 09:11 PM
Ocotillo
Mar 29, 2005 09:14 PM
