T-bit to remove rotor
Old Sep 29, 2012 | 03:24 PM
02VolvoS40's Avatar
Default T-bit to remove rotor
Anyone know what size I need for my 2008 S80 to remove the bolt that holds the rotor on?
Old Sep 29, 2012 | 06:36 PM
jriggs87's Avatar
I believe a 10mm. Its not screwed on very tight. If you have an adjustable wrench or even vice grip pliers, they will do the trick. That bolt is really only used to keep the rotor on during assembley and if you want you dont need it. After that bolt is off you will still need a rubber hammer to get the rotor off the hub.
Old Sep 29, 2012 | 09:52 PM
02VolvoS40's Avatar
Ok, thanks for the tip!
ICE
Apr 8, 2009 11:36 AM
Capo Cam
Jul 1, 2008 02:14 PM
xc90guy
Apr 2, 2008 10:28 AM
SkottinNJ
Oct 9, 2006 12:07 PM
