Timing belt dealer recomendation
Old Jul 18, 2009 | 03:48 PM
jmallie's Avatar
Default Timing belt dealer recomendation
I have a 2002 T6 with 97k and I am going to have a dealer or Indy Volvo shop repalce the timing belt. I have prices from two dealers both with good service reputations and one that has always been a little expensive but does a good job. One dealer sells and services multiple car brands (Hondas, Jags, BMWs Volvos etc). I asked both service agents what they do as the recomended service.
One changes the timing belt, idler and tensioner for $675. They inspect the water pump and recomend that you leave it alone if there is no sign of a leak, they inspect the serpentine belt and leave it alone depending on the condition and when it was last replaced. I pushed on the water pump and they said it usually is not a problem for at least 150k and if it is not leaking by now it may go 200k miles - - don't mess with it.
The second dealer does the timing belt, tensioner, serpentine belt and an oil change for $689. I pushed on the water pump and thermostat and was told they only replace them if there is signs of a problem and unlike the Hondas and other cars they also sell and service, these water pumps do not usually fail. They only do the idler if inspection shows a problem.
The parts department indicated the water pump and thermostat kit are about $212. I think the idler is about $70 on Groton. I am thinking if the belt must be removed to do the thermostat I do that as it is a $20 part and the idler ( are there two?) and the serpentine, but not the water pump.
I will call the dealership I normally deal with and speak to the service manager, but would appreciate comments.
sailbode
Jun 15, 2011 07:44 PM
jmallie
Oct 16, 2009 12:06 AM
jmallie
Oct 3, 2009 09:43 PM
Qamar
Aug 24, 2005 07:37 PM
mphubbar
Aug 12, 2005 01:28 AM
