Transmission Seal Leakage
Old Jul 24, 2012 | 09:12 AM
placervillebob's Avatar
Default Transmission Seal Leakage
2004 S80 2.9L non-turbo Auto FWD 88,000 mi. Non-Viscous clutch
After replacing my Right (Passenger) side Drive Shaft, I am now having a little leakage at the Transmission Seal (where the shaft plugs into the tranny). Everything went fine during the remove & replace, however when the old shaft was slid out of the transmission, about a pint or so of transmission fluid drained out – IS THIS NORMAL? The seal was evidently keeping this fluid contained. When I completed installing the new shaft, I replaced the pint of fluid and took it out for a test drive. Everything looked and felt good – no leaks at that point. After checking the transmission fluid level – I found it was a little high – wish I hadn’t put in that pint. After a week or two of driving I have developed a leak coming from the seal/shaft area. I have a few questions:
- Should I replace the seal & how difficult a job is it? Is it a pry it out and tap the new one in type of job?
- Should I remove the shaft and let the trapped fluid drain and re-install the shaft – but this time don’t replace lost fluid?
- Is there supposed to be tranny fluid in this area or is that a result of over-filling?
- What sort of function does this seal provide? Is it to keep dust/dirt out (like a wheel bearing seal) or is it to keep tranny fluid in – in other words is this an active reservoir of the transmission fluid?
Any comments would be appreciated.
Thanks
placervillebob
cheewooi
Jan 20, 2012 12:32 PM
Titan Joe
Oct 3, 2010 03:30 AM
De005
Nov 11, 2009 02:54 PM
fpisvin
Aug 11, 2009 10:53 AM
loopcharged
Mar 26, 2008 04:19 AM
