Transmission spline play?
Old Oct 26, 2010 | 08:34 AM
travismail's Avatar
Default Transmission spline play?
I just replaced both axle assemblies in my 02 S80 and noted some play in the spline that is inside the transmission that the driver's side axle is fitted to. Does anyone know if this is okay or should it not have any play to it? I do notice a slight knock when I jab at the gas peddle and it sounds like it could be this component hitting transmission wall. I wonder if a bearing has come out of place on this spline diff axle. The entire front end of car has basically been replaced so it is tight as a drum. Any thoughts?
Old Oct 26, 2010 | 08:37 AM
travismail's Avatar
FYI...the transmission also has been rebuilt about 60k ago
Old Oct 26, 2010 | 07:13 PM
537playing's Avatar
It will have some play. I bet you need a new transmision mount.
Old Oct 27, 2010 | 07:04 AM
travismail's Avatar
the torque rod mount under the motor/trans?
Old Oct 27, 2010 | 04:12 PM
537playing's Avatar
Yes, that's the one.
Old Oct 27, 2010 | 06:18 PM
travismail's Avatar
I have looked at the torque mount recently when I did my transmission fluid and filter change but it looked like the rubber bushings where only slightly cracked not enough to create a lot movement. Maybe it is moving more then thought. So you have seen some play in the spline that comes out of the driver's side transmission because I really thought that was it but I could be wrong. Thanks again for your insight.
Old Oct 27, 2010 | 08:50 PM
537playing's Avatar
I did replace my axle with a rebuilt one while I had things apart. But it didn't make the car shift quieter. But replacing that torque mount did make a difference. And mine looked good also.
Old Oct 27, 2010 | 09:38 PM
travismail's Avatar
but you do remember the spline on the transmission had noticeable play?
Old Oct 28, 2010 | 04:03 PM
537playing's Avatar
Noticeable? I know that there was movement but how much I can't recall. It defimitely wasn't stiff.
Old Oct 29, 2010 | 07:26 AM
travismail's Avatar
Thanks. As long as you remember some play in it I am comfortable that it is fine and I must have movement in the engine. Probably a motor or torque mount. I will have to look more closely there.
Catchincotton
Jul 6, 2016 10:02 PM
VolvoDriver
Oct 7, 2006 03:02 PM
Ebolavoodoo
Sep 29, 2006 01:04 PM
cbatterman
Apr 8, 2006 02:42 PM
