Turbo Leaking Oil--2002 S80 T6
Old Nov 20, 2013 | 02:55 PM
wjs1919's Avatar
Default Turbo Leaking Oil--2002 S80 T6
Hello Everybody--My. S80 T6 was leaking oil under the black cover where the coil packs are--a friend said it looked like crankcase ventilation problem--is there a way you can test for this--btw the dipstick was pushed out of the holder and oil was present on the engine--just turned 91,000 miles car runs great-car is a 2.9 twin turbo-Thanks For Any Help Iam takeing the car to a mechanic later today will reply back after -----
Old Nov 21, 2013 | 08:05 AM
majorcode's Avatar
Get your engine check completely, I suspect the PCV Oil trap is clogged and created the mess, surly you got your engine seals leaked, you have to take out all covers to check.
Good Luck!
Old Nov 22, 2013 | 08:10 AM
wjs1919's Avatar
Thanks for your advice--oil was leaking under the cover on top of engine --coil packs were covered --mechanic said it was crankcase ventilation problem had th car for week,said it was done-drove the car for aweek -went to check the oil and clean up the engine --ran my fingers under the turbo pipes and came out with oil---the oil where the coil packs are was dry--dont know what he did allthe bolts and screws looked like they were never touched --seem to me whatever he did --the oil problem was deverted to another part of the engine--now he tells me that one of the turbos are bad--already have 2450.00 invested a lot of other things poped up after the worked was done--told me the serp. belt and tensioner was bad --new timming belt and tensioner water pump--brake booster and master cylinder--now i have an error code P0011 & P0014--could be the camshaft position sensor---misalignment of the timming belt--or too much oil going to the vvt dont know what tht is--still stuck---thanks for your advice---buzz
Old Nov 23, 2013 | 05:39 AM
majorcode's Avatar
wjs191 crankcase ventilation problem happens when your PCV Oil trap gets clogged.
Anyway, first think you need to do change the mechanic and try to find the best one, referenced mechanic will be preferred.
While engine hot take the dip stick out and see if there is any smoking coming out.
Since you have posted too many problems which I am sure your mechanic did. Always before giving car to mechanic show him the dashboard error messages.
Do not drive the car since there is Timing belt misalignment, but meanwhile do try to find a reputed Volvo mechanic.
cjlongo
2001-2013 model year XC70
Sep 14, 2013 06:03 AM
supernicguy
Jan 22, 2010 06:21 PM
mercb
Dec 11, 2009 01:49 PM
NCS60
Apr 5, 2007 12:53 AM
MattB850in
Mar 29, 2007 03:55 AM
