Turn signal light
Old Nov 24, 2009 | 03:40 PM
tactic's Avatar
Default Turn signal light
I just had a turn signal assembly replaced and now my turning light wont turn on when headlights are on. The turn signal still works when turning, but will not stay on steady. The other side will stay on steady, but not the drivers side. Its not the bulb, I replaced it already. Any ideas?
Old Nov 27, 2009 | 04:29 PM
resbnoki's Avatar
i got a customers 2000 s-80 non turbo.
originally i got engine codes P0751- shift solenoid A performance stuck open
and P1618.
I ordered all 4 solenoids from GM as they were alot cheaper., i replaced them and after the job the car went back into limp home mode(starting in 3rd gear) and the engine light came back on. this time the P0751 code is gone but i still get the P1618 code. i used my cheap generic scanner to get these codes.
So i brought it to the dealer and the scanned the car. A whole list of codes came up with 2 hard codes- shift solenoid 1 and an srs seat buckle. they told me that they can no clear any codes until the hard codes are fixed. with a generic code reader you can clear the codes and see which ones come back. the very expensive volvo scanner can not do that. that does not make sense.
Old Nov 30, 2009 | 11:46 PM
80z1r's Avatar
The bulb socket inside the new turn signal is for a 1156 bulb,return it and make sure you ask for a turn signal assembly that accepts only a 1157 bulb.1157s are dual element bulbs(turn/running light) with offset holding pins,1156s are singal element bulbs(turn signal only) with parallel holding pins.
suckonthiscaravan
Dec 5, 2018 03:19 PM
Jonboy
2001-2013 model year V70
Apr 17, 2013 11:12 PM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
