Wiring Diagram to S80 tranny shifter? plz some1?
Old Dec 18, 2007 | 10:20 PM
Lab_Rodent's Avatar
Default Wiring Diagram to S80 tranny shifter? plz some1?
I thought someone with a working VADIS program could give me the wiring diagram for the S80's manumatic/geartronic shifter. I have some wireing diagrams, but none are to this exact model. Maybe someone could give me a screen shot. I am trying to figure out wire colors to the up & down shift buttons that are connected to the stick.
Old Dec 19, 2007 | 05:35 PM
Default RE: Wiring Diagram to S80 tranny shifter? plz some1?
Give me a day or so if you can wait that long and I will try to get it for you.
Old Dec 19, 2007 | 11:03 PM
Lab_Rodent's Avatar
Yeah', no problem. TY!
Old Dec 20, 2007 | 07:07 PM
Not sure if a diagram will help or not.
I have to replace parts on a shifter today. It is a very weird setup for the geartronic.
There is a sensor that mounts under the cover. The shifter itself has like a magnet on it that tells the computer which gear it is in.
Not sure if you could bypass to install the paddle shift or not.
Old Dec 22, 2007 | 03:58 PM
Lab_Rodent's Avatar
Sounds as if it uses magnetic buttons. I know that in order for the TCM to get the signal to shift up or down once in geartronic mode, a button has to be pressed. When you put the shifter down into the geartronic section you press it back and forth to shift. When you press it forward it triggers or presses a button, same as when you pull it. Magnetic triggers, or what ever, it doesnt really matter as long as the shifter box doest use a computer itself in order to operate. Which I saw no signs of one when I was looking. I doubt the shifter box is that fancy seeing there is no need for it to be, plus that is what the TCM is for.
Old Dec 23, 2007 | 12:09 AM
But on some of the years the shifter plate is a computer.
I will still see what I can come up with.
Old Dec 23, 2007 | 11:54 PM
Lab_Rodent's Avatar
even then, it could still be done if you took it all apart. I am just not willing to go that far for it.
Old Dec 24, 2007 | 02:22 PM
Pm me with your E-mail address I have a couple to send you. Still looking for the index.
Old Dec 29, 2007 | 04:30 AM
Lab_Rodent's Avatar
TY for the pics! But do you have the legend for them? All the lines are lettered, but I have no legend for it.
Plus, I see that is a big PDF file. If you have the top of the tree selected and press "save as", you should be able to save it seperate. If you could do that, you could upload the PDF for me. pretty please?
Old Dec 29, 2007 | 06:05 AM
Im not sure if I can save it any smaller I am cheating already. They made the program so you can't copy it. I figured out a way to copy but don't think I can make it any smaller.
I will try to find the legend that is also really big.
Old Dec 30, 2007 | 08:44 AM
What year is it to make sure I get the proper info?
Old Dec 30, 2007 | 04:58 PM
Lab_Rodent's Avatar
I have a 1999
Old Dec 30, 2007 | 06:46 PM
OK I was searching and trying to send you the entire file but it is way to large and I cant get it to compress enough.
Old Dec 30, 2007 | 08:56 PM
Lab_Rodent's Avatar
You will need to upload it to a website, then give me a link to it. This place will do it if it is under 25mb. http://www.yourfilehost.com/index.php
This place can be NWS (pics), but it works without neededing an account & can uplaod anytype of file.
If the file is larger, tell me how large it is and I can find another place.
Old Dec 31, 2007 | 05:00 PM
It is 66.43MB
xDread92x
Jul 21, 2019 04:18 PM
zandrew
Jun 1, 2014 09:50 PM
Skribb
Nov 29, 2010 09:59 PM
jasond011
Sep 13, 2010 04:02 PM
sandraqu
Dec 24, 2009 02:36 PM
