1997 Volvo V90 Engine vacuum leak (?)
Old Oct 23, 2018 | 01:17 PM
AfonsoF1999's Avatar
Default 1997 Volvo V90 Engine vacuum leak (?)
Hello, well my 1997 V90 has developed a problema on recent weeks and I can't figure it out.
Every time I rev the engine it makes like a whistle noise, has troubles to start at the first try and when driving it makes a very loud exaust rumble. I suspect its a vacuum leak but cant find any.
Any help?
Old Oct 24, 2018 | 04:40 PM
exhaust rumble? not sure if your model has a flex pipe section in the exhaust, but that's a common failure point on other models. as to the whistle, does it go away if you pull out the dipstick or open the oil fill cap? If so you may have a clogged PCV. If you had a vacuum or intake leak, you'd likely throw a check engine light for a fuel trim issue and would possibly have a rough or wandering idle.
Old Oct 24, 2018 | 05:48 PM
I tried running the engine without the dipstick and it didn't stop.
Oh and I forgot to mention the engine os really down on power.
Old Oct 25, 2018 | 08:27 PM
you can try spraying around with some carb cleaner on intake air hoses, seams and vacuum lines. if nothing, a shop may need to do a smoke test.
Old Jan 13, 2019 | 03:41 PM
tylswil's Avatar
Any help?
maybe be a long shot but maybe a clogged catalytic converter?
GrantRobertson
Jun 6, 2013 12:30 AM
rolltide
Jun 15, 2011 08:45 PM
Billc
Feb 6, 2010 07:17 PM
Sofar.
Feb 9, 2009 02:56 PM
nick54
Dec 21, 2006 07:21 AM
