rough idle and pinging S90
Old Dec 21, 2012 | 12:13 AM
brick'n it's Avatar
Default rough idle and pinging S90
hey new to the forum and really need some help with my beloved 97 s90
i was on my home from work one night and was attempting an 'Italian tune' running it at 5k+ and over the coarse of about 10sec it went from normal loud pinging and a loss in power. pulled over and it stalled at 1k. got it started again and limped it home. the next day i check the oil and there was none...
i had just topped it of less than 1000 mi prior. so 6qts later were back at top of the dip stick. knock sensor is picking up a misfire in cyc 4 & 5 as well as a random interval misfire. not sure if its actually misfiring or not, i did replace the spark plugs to no avail. also i brought it up to temp yesterday and smoke/oily steam was coming from the dipstick tube. have not been able to do a compression test yet but i was wondering if anyone could help push me in the right direction. it does have a vacuum issue as well and i totally confused by the vac system i havent seen any clear diagrams yet.
any help would be great, would love to get the old girl back on the road.
Old Dec 22, 2012 | 06:53 PM
tosoutherncars's Avatar
Wow, where to start...
Where did your oil go?
- is it showing a lot of blue smoke on acceleration? On start-up?
- is there oil in your coolant?
- are there 6L of oil on your driveway? Is it dripping / leaking?
How healthy is your PCV system?
Any signs of overheating?
Old Dec 22, 2012 | 08:49 PM
Hi Bricked, welcome to the forum.
Step #1, do a compression test. Low compression causes misfires. Sounds like you blew a RMS. If your breater system is clogged and you put your foot in it, it will likely blow seals.
How long have you had this car?
Old Dec 23, 2012 | 12:19 AM
brick'n it's Avatar
hey thank you for the feedback
and to answer tosoutherncars
no blue smoke at all, coolant is clean, no leaks to speak of.
i refilled it and it doesn't seem to be leaking at all...
i pulled the intake hoses to inspect the throttle body and it was caked in oil, also had a small pool in the bottom of the intake manifold. it seems to becoming from the PCV tube, and the flame trap is caked as well. when i pulled the tube off the intake hose is was smoking as was the dip stick.
and i will hopefully be getting a compression test gauge soon. If it is a RMS what are my options i hear its a pricey fix. still not sure where my oil went other than though my PCV i guess.
i have had my volvo for 3 years and havent treated her as good as i should have. i didnt know much about volvo's when i got the car, and if can get her back on the road plan to treat her right.
Old Dec 30, 2012 | 02:10 PM
brick'n it's Avatar
well thanks for the input guys, but i killed my car. moving it for the plow the other day herd a loud bank and she stopped dead. by the time i got out to check there was already a puddle of oil on the ground. didnt even bother trying it again. so on a very sour note any one need a 97 S90 parts car :-(((
Richard Lane
Nov 21, 2010 07:35 AM
tresjolie2
Nov 7, 2010 07:33 AM
1991_240wagon
Aug 6, 2009 07:22 PM
trlwys
May 7, 2008 05:57 AM
jktiffin
Jul 24, 2006 08:32 PM
