'86 240DL engine "pinging" problem
Old Jul 14, 2006 | 11:53 AM
jktiffin's Avatar
Default '86 240DL engine "pinging" problem
The engine "pings" when under load. I believe the correct term is pre-ignition (?). What causes this? is it bad for the engine and how do I solve this problem?
Thanks
John
Old Jul 14, 2006 | 03:18 PM
TedH's Avatar
Default RE: '86 240DL engine "pinging" problem
your timing may not be correct. check that first.
Old Jul 19, 2006 | 01:00 AM
jktiffin's Avatar
My mechanic suggested using 89 octane for a tank load, which I am doing, before doing tune up and timing. Seems to help (maybe psychological?): engine seems to be running more smoothly with less pinging, tho' it is still pinging under load. Could the octane have this effect?
Old Jul 24, 2006 | 08:32 PM
sdchuck1's Avatar
Not to overly sure about your car but my new 83 turbo was pinging anytime I gave it a good amount of pedal and after poking around I realized that the vacuum advance diaphragm was stuck closed and I attached a clean hose and worked it by lung power till it was operating smoothly and now my car runs awesome and has power all the way to redline if I wanted to push it that hard. Pop the cap of the distributor and remove the hose from the vacuum pot attach a clean hose and give it a nice pull wia your mouth and watch for the arm that goes into the vacuum pot to move alittle.
brick'n it
Dec 30, 2012 02:10 PM
Richard Lane
Nov 21, 2010 07:35 AM
tresjolie2
Nov 7, 2010 07:33 AM
1991_240wagon
Aug 6, 2009 07:22 PM
trlwys
May 7, 2008 05:57 AM
