Poor Fuel Mileage/Pinging
Old Apr 29, 2008 | 10:12 AM
trlwys's Avatar
Default Poor Fuel Mileage/Pinging
98 S70 - poor mileage (<24MPG), pinging under acceleration....MAAS? Check Engine indicates "long-term fuel delivery problem.." No fuel leaks, no vacuum leaks -new fuel filter....cleaned MAAS - no change..time to replace?
Old Apr 29, 2008 | 06:53 PM
Default RE: Poor Fuel Mileage/Pinging
Mass Flow might be bad.
Old May 1, 2008 | 10:31 AM
air force rascal's Avatar
Could it be maybe a Knock Sensor..?
Old May 7, 2008 | 05:55 AM
JPN's Avatar
JPN
+1 to Tech.
Also, when was the last tune-up? If the MAF sensor turned out ok, switch fuel grade (unless you're already running 91 or higher), dump a large bottle of Techron fuel system cleaner into a half-full tank and replace ignition components if not done for a while.
Try not to drive the car if it keeps pinging. It can destroy the engine if persisted at certain levels.
The attached are taken from the 850 manual and may not apply to the S70. It may be of some use, however.
JPN
[IMG]local://upfiles/6892/FD5BBDBCBFE94540AAA682466C1982F8.jpg[/IMG]
Old May 7, 2008 | 05:57 AM
JPN's Avatar
JPN
Trouble-shooting for Long Term Fuel code seems a bit involving and seems to require Volvo scan tool.
JPN
[IMG]local://upfiles/6892/44810E16481248DCB66FA6186CA21D4D.jpg[/IMG]
tresjolie2
Nov 7, 2010 07:33 AM
chadman551
Feb 25, 2010 12:05 PM
1991_240wagon
Aug 6, 2009 07:22 PM
jdjayakaran
Jun 27, 2007 12:57 PM
jktiffin
Jul 24, 2006 08:32 PM
