2004 v40 windscreen washer motor and pump
Old Sep 6, 2018 | 03:12 PM
Jayv40's Avatar
Default 2004 v40 windscreen washer motor and pump
Hi
Anyone know where this is located?
Thanks
Old Sep 9, 2018 | 10:44 AM
tony1963's Avatar
The washer motor/pump assembly are directly attached to the reservoir. You need to remove the front bumper cover to access it correctly.
Old Sep 9, 2018 | 11:25 AM
Tony, can it be accessed by removing the lower valence (ie the plastic part that goes under the radiator/fender to fender)? I need to do the same job on my son's S40... I took a look around and was wondering about the bumper cover or the lower valence as a way in...
Old Sep 9, 2018 | 01:02 PM
tony1963's Avatar
In my experience, by the time that you try and wrestle this thing out of the car without the bumper cover off, you'll spend more time than if you just removed the bumper cover. Removing the bumper cover takes about 20 minutes. From there, the washer pump job is a breeze.
southwesty
2001-2013 model year V70
Aug 8, 2018 03:40 AM
Egco
Oct 18, 2016 03:41 PM
wgan
Mar 21, 2016 09:17 PM
Dieterly
May 13, 2015 08:54 AM
retrohwam
2001-2013 model year XC70
Oct 14, 2013 02:40 PM
