V40 2.0 T4 1999 - Takes 5-10 seconds to start.
Old Oct 4, 2013 | 08:48 AM
stormee's Avatar
Default V40 2.0 T4 1999 - Takes 5-10 seconds to start.
Hello guys,
bought this car few weeks ago, it runs nicely and is otherwise great, except the annoying starting issue.
When i start it on a cold engine, it takes 5 to 10 seconds of cranking before the engine starts. Battery and starter are fine and spin nicely.
When the car is warm, and i stop the engine for few minutes, it starts on first crank.
However if I leave it for 15-20 minutes, the slow starting usually happens again.
When i start it cold, it usually goes on 3 or even sometimes feels like on 2 cylinders for 10-15 seconds, and then normalizes and runs fine.
Shall i begin with changing the plugs or is it something else?
Old Oct 4, 2013 | 09:00 AM
stormee's Avatar
After some searching figured it could be the FPR, as it seems to be a common problem.
Could someone experienced please confirm this:
to test FPR I leave the car off for 30-60 minutes, then I pull off the intake connector from FPR and see if it leaks fuel. If it does - look for a new FPR.
Can someone who knows how it looks give a detailed advice please, so i don't pull something unnecessary off ; )
Or maybe some pictures?
thanks in advance guys
Old Oct 5, 2013 | 06:37 AM
Ripkord's Avatar
Most definitely your fuel regulator. I had same issue with 2000 V40. Found new regulator for around $80 US.
Installation time 10 minutes. Wear eye protection, you will have latent pressure that may spray a bit of fuel when you pull the line from old reg
Old Oct 8, 2013 | 02:40 AM
stormee's Avatar
Aight, thanks for the advice : )
Found the part, should be with me in 2-3 days. Hope I dont screw up the installation :P
Old Oct 21, 2013 | 03:59 PM
stormee's Avatar
Replaced the FPR yesterday and it helped the car now starts at the first crank and doesnt misfire anymore.
this guide helped a lot, and is right on the spot, with perhaps a couple tiny things that didnt match but thanks to the guy who made it ; )
Guide: How to remove and replace a fuel pressure regulator - Volvo Owners Club Forum
migbro
Mar 24, 2018 10:22 AM
EricNR
Jul 6, 2010 08:23 PM
m300slr
Nov 18, 2008 09:02 PM
samloz
Oct 15, 2007 07:15 PM
