Volvo V40 engine stops when hot !!!?? Help please !!!!!!
Hi Everydody !!!!!
Thank you to try to hep me out .... I have a Volvo V40 1.9T 2001. As soon as the engine is HOT and the fans are starting to work the engine stops by himselfas soon that I have the foot on brake...actually when the engine is as his low rpm level.I only does it sometimes ,maybe 1/2 when I am at a stop light or i'm in drive and I have the foot on the brake and the car is completely stoped.
I went at Volvo and they couldnt find anything beacause there is no check engine on. I changed the alternator ...the timing belt ...batterie,air filterand same story.....If you guys have any ideas please let me know .... Thank you again ...
RE: Volvo V40 engine stops when hot !!!?? Help please !!!!!!
Thank you again , but it dies like it will be an electrical probelm. The engine stop instantly. and if I try to restart it start normaly... I know that it could be anything...it s preatty sad cause this could ba cause by anything... but I will try to see if what u said could be the problem . thanx again
autobeef
10-17-2007 12:00 PM
