2005 Timing belt oscillation damper noise
Old Jul 17, 2024 | 11:54 AM
Jim1800es's Avatar
Default 2005 Timing belt oscillation damper noise
I recently change my timing belt. In the process I removed the oscillation damper ( harmonic balancer) using my impact wrench. On the refit I used the impact wrench to tighten the crank shaft nut. The first attempt there was was a fairly significant whuup whuup whuup noise after a 10k test run. I retightened the crankshaft nut and the noise is much fainter but still there.
My question is about the balancer. I saw somewhere that you should not use an impact wrench, you must be careful when pulling the damper off, the damper has a life expectancy less than that of a timing belt.
So, did I corrupt or compromise the damper during removal and refit ?
What is the best process to follow ?
Is an aftermarket balancer a good idea or do I have to get an OEM one ?
The car runs great - fun to drive T5 M66, has a lot of K on it, not worth spending a lot of money on it.
Thanks for any comments
majorcode
Oct 30, 2014 10:06 PM
slimflex2
Jan 8, 2012 06:25 AM
gmc021
Apr 1, 2009 08:29 PM
patricknlisa
Feb 3, 2009 04:11 AM
kkboyvolvo
Jul 10, 2006 09:15 PM
