Engine whistling noise and check engine on
Old Dec 14, 2011 | 07:40 PM
Rafiolo's Avatar
Default Engine whistling noise and check engine on
Hi there
I have 2005 Volvo V50 2.4i with 72k. Lately I can hear some whispering noise coming from an engine area. Also check engine lamp is on with code PO171 System too lean (bank1) . Any suggestions? Can it be oil trap ? I changed oil 2 weeks ago. Maf sensor error? Maybe some broken hose?
Old Dec 14, 2011 | 08:00 PM
Rafiolo's Avatar
Can it be a vacuum leak?
Old Dec 19, 2011 | 11:58 PM
mike.k's Avatar
Same car here, same issue. I removed the upper intake manifold and saw that the old oil trap hose was busted, and replaced it. Now it whistles even worse.
I cant get a good handle on how the vacuum is done on this engine, even with the diagrams. When I pull the hose off from the oil trap while its running, the noise is gone and the car runs FINE. As if it doesnt even matter if you have the hose or not.
I'm going to try removing the plastic top from the oil trap and see if there is something there I can clean up, because it had no air pressure at it's hose connector at all, and it should've been pushing oily air out to the head via the hose.
Old Dec 20, 2011 | 05:53 AM
Rafiolo's Avatar
Ok thanks.. It seems that the whistling noise was from one of the belts. So it is not related to the check engine lamp. Now the lamp went off so I will wait and see what happen.
Old Jan 1, 2012 | 02:34 PM
ltpreston's Avatar
Default PCV and oil trap
I had this happen a few years ago. You have to replace the PCV and oil trap. Since this is part of the emissions system, Volvo may reimburse you for the expense, even if your warranty is expired. You may have to call Volvo Customer Care Center (1-800-458-1552)
abiets20
Jun 22, 2013 03:09 PM
SDozier
Mar 19, 2011 03:43 PM
01Vs40
Jan 12, 2011 09:33 PM
nmh
Jul 15, 2010 05:18 PM
danielribo
Oct 23, 2005 06:38 AM
