Loving my v50
Old Jun 13, 2010 | 09:36 PM
a4ty4d's Avatar
Default Loving my v50
I just purchased a 2007 v50, non-turbo. I am really enjoying this car. Given the activity on this forum and not even knowing about the v50 prior to looking at my car, I can only assume it is fairly rare, at least in the Southeastern United States. Are they generally rare in the US and elsewhere?
John
Old Jun 18, 2010 | 11:34 PM
AutoNaut's Avatar
They do seem to be a little rare. I thoroughly enjoy mine.
Stan
Old Jun 19, 2010 | 10:48 AM
SVTfocusO3's Avatar
I would invest in some battery terminal washers, the negative corrodes a lot, check yours.
Old Jun 19, 2010 | 12:59 PM
AutoNaut's Avatar
Mine was corroded but it was because it had a leak around the terminal. Volvo replaced the battery.
Stan
Old Jun 20, 2010 | 06:50 PM
a4ty4d's Avatar
Default thanks
Thanks, I will check out the battery. I haven't even the Haynes manual yet (I don't know if Bentley publishes one for the V50) I want to change the oil to synthetic (Mobile 1, 0W-40W, will price out Amsoil). I have never dealt with the canister type oil filter. What is up with that? How do I change it and the oil?
John,
1940 Ford 3/4-ton express pickup
89 240 DL late
91 245 SE
94 850 late
98 V70
07 V50
Old Jun 20, 2010 | 10:56 PM
AutoNaut's Avatar
I like the oil filter. There is less waste going into the environment and you can inspect the filter element for debris. To change it you will need to remove the air intake snorkel that goes into the air filter box (2 bolts). You will need a ratchet wrench with extensions, a universal and special socket http://www.ipdusa.com/version.asp?st...=415&V_ID=2726
You may be able to find them cheaper.
To get to the oil drain plug, you will have to remove the plastic cover that is under the engine compartment. This all sounds complicated but it really is quite ease.
Stan
Old Jun 21, 2010 | 11:16 AM
SVTfocusO3's Avatar
You might find a 36mm socket somewhere and be able to use it on a swivel. Keep an eye on that battery though, it will still do it again.
Old Jun 28, 2010 | 10:01 PM
a4ty4d's Avatar
Default V50 oil change
If one scratches one's head long enough, one can figure anything out. But why re-invent the wheel? I want to change my oil on the '07 v50 I just purchased. I get dropping plastic pan from the bottom. I am sure I can find the drain plug on the pan. I see where the filter goes. I found a 36mm socket at the corner parts store and a special tool at ipdusa. I guess that is six of one and a half dozen of the other -- both would probably work. I presume the top to the oil filter comes of counter clockwise I take the old out and put the new in. Where does the gasket go? Does it go on the lid or elsewhere? Do I put any oil in with the new filter? or does all oil go into the oil filler after the filter is in place? I am looking for a few more detailed pointers to make changing the oil for the first time a little more easy.
Thanks,
John
Old Jun 29, 2010 | 10:40 PM
SVTfocusO3's Avatar
ok John, here it is...
1st, remove the oil filler cap and pull the dipstick up, this is my personal preference.
2nd, remove any air inlet tubes to access 36mm oil filter cap,
3rd, UNSCREW oil filter cap all the way, but DO NOT REMOVE,
4th, remove pan under engine, and remove drain plug, 17mm, let drain
5th, install new washer on drain plug and install till crushed, install cover.
6th, REMOVE oil filter cap and discard filter, and O-RING on cap, make note of location.
7th, install o-ring on cap, lubed, place filter in HOUSING, snug, then install cap.
8th, install other parts taken off, fill with oil, 6 qts, secure everything.
Old Jun 30, 2010 | 06:14 AM
a4ty4d's Avatar
Default Thanks
Thanks for the check list. This will be a big help.
John
brick babe
Dec 6, 2010 02:08 PM
Aimee
Mar 19, 2009 02:09 PM
mfroese
Jan 6, 2009 12:02 PM
Little257622
Dec 11, 2008 04:24 PM
mikeys
Sep 28, 2006 11:43 AM
