Manual mode not working
Old Aug 6, 2011 | 07:14 PM
higogo's Avatar
Angry Manual mode not working
Hi there,
Any idea why transmission manual mode will stop working.
2006 Volvo V50
Old Aug 6, 2011 | 10:34 PM
AutoNaut's Avatar
Does it shift the same as if it were in auto mode? Or does it delay in shifting?
Old Aug 14, 2011 | 09:55 PM
higogo's Avatar
Default Just Manual
In Auto it works just fine, the problem is with manual. It stop working, it stays showing the "D" all the time even if you try shifting up or down. Could it be that the plastic piece that moved with the stick is broken?
Old May 5, 2014 | 10:57 AM
Wxj's Avatar
Wxj
Default Volvo S40 T5
Hi
Did you ever get this resolved?
I have the same issue but the plastic is OK
Richard
Old May 15, 2014 | 07:25 AM
v5024's Avatar
Banned
Hi, I've had the same issue and basically what happened was this:
Your picture that you had posted shows a huge gap, that's what broke on my old 2006 V50 as well. We got that replaced and yes, of course it was $300. But what they forgot to put back in was the 'magnet' which controls this. Another user on this forum created a post exactly like this and it turns out he put the rigid side of the piece facing upwards instead of the smooth bit upwards (the piece you see on your shifter). The magnet needs to be replaced by your Volvo dealer I think, or at least, that's where I always got the V50 repaired/serviced at. I can't remember how much it cost to get it placed back in, but that's what you need, including a new surface piece for your shifter to prevent this from happening again. The magnet could even be somewhere underneath your shifter...
Here's the thread bv524 created (the person who had a similar incident to you) - hope this helps and do let us know once you've fixed it/have an update!
https://volvoforums.com/forum/volvo-...rtronic-76195/
P.S: This thread was running great until someone thread jacked it, so after a few posts you will realise it's completely irrelevant.
Hope this helps you out!
Old Feb 1, 2015 | 03:00 PM
Enrizalez's Avatar
I have a S40 AWD 2006 with the same problem described by Higogo. The plastic piece inside get Broker the the manual option stops working. It can only be repaired at the Dealer?
Old Feb 9, 2015 | 04:26 PM
bv343's Avatar
The broken piece in the OP's pic is the shifter blind. It's fairly easy to replace if you're mechanically inclined. Part is cheap at US$14 from online stores.
Here's a link to another forum that has a step-by-step procedure with pix. The hardest part of doing it is pulling the gear **** off, takes quite a bit of muscle power to pull straight up. Not much leverage room but it can be done, if a 165lb weakling can do it! :-D
2004-2007:
shifter blind how to
2008-2017:
2008 - DIY remove waterfall and auto shifter...
Old Apr 25, 2015 | 05:14 PM
Enrizalez's Avatar
Smile S40 Geartronic Shifter blind replacement
BV343,
Thanks a million! You gave me all information needed to replace the Shifter Blind (pn:8699465). I ordered online the part ($30 including S&H) followed the instructions in the two links you posted.. Done! (yes, removing the **** was a pain..., but it was worth the effort).
Thank you all!
Old Jun 1, 2018 | 11:43 AM
LinkFL's Avatar
Shifter blind needs to be replaced. Very common, youtube has instructions
bv343
Apr 23, 2022 02:25 PM
RichyRich
Oct 23, 2021 06:47 PM
River.davis
Oct 8, 2017 11:22 AM
SABS
Nov 5, 2013 12:20 AM
SamTheMailman
Mar 24, 2012 10:03 PM
