V50 Oil Change Questions
Old Oct 10, 2012 | 04:52 PM
dpaterl's Avatar
Default V50 Oil Change Questions
Hi All, Volvo newbie here. 2 simple questions for the group:
1) What is appropriate mileage for oil change? The dealer told me 7500 but I'm skeptical.
2) Do I need to go to the dealer for this or can any quickie-lube place do it?
Not a car guy here so simple decisions like this cause anxiety! Thanks!
Old Oct 13, 2012 | 03:21 AM
patricklaw7's Avatar
1) It really depends. 7500 is on the high side for regular oil but just about right if you are using synthetic. I would recommend 5000 miles and synthetic oil just to be safe.
2) I doubt the quickly lube place could carry the filter required. On the other hand, it is not that hard to change the oil yourself. You need a 36mm socket to loosen the filter cap. I also remove the air filter duct before removing the filter so it is less of a mess when pulling out the filter.
Old Oct 15, 2012 | 01:19 PM
dpaterl's Avatar
Default Thanks!
I'll give it a go - thanks Patrick.
Old Oct 21, 2012 | 02:56 AM
Chadwik50's Avatar
Default Good
All the contents you mentioned in post are too good and can be very useful. I will keep it in mind, thanks for sharing the information keep updating, looking forward for more posts.
buy google +1 votes
Old Oct 22, 2012 | 07:14 AM
dpaterl's Avatar
Default Question Followup
All, just a followup to my initial question..
I took Patrick's advice and will go every 5K miles. I did contact the Volvo dealer and they said synthetic was not necessary but can't hurt. Apparently this is a difference between Volvo vs. Audi/BMW - they require synthetic.
Last - I went to a quickie place (Valvoline) and they did have my filter. $5.99 seemed reasonable to me!
ThomasK
Feb 7, 2015 07:30 AM
Phil 850
Jul 25, 2012 10:01 PM
shayne1106
Apr 18, 2012 06:08 AM
varioram
May 2, 2010 12:06 AM
mekump
May 5, 2009 10:22 AM
