'03 V70 not starting
I have a '03 V70 2.4T with 55K miles. For the past two months I've had intermittent issues with the car not starting. When I turn the key I hear a click, but the engine won't turn over. All lights work fine. I've tried jumping it with no success. I've had it towed to the Swedish specialty shop a couple of times with a different diagnosis each time. First they replaced the Starter Relay, car worked fine for a week or so. Then it wouldn't start again, so I took it back and they replaced the starter, same thing happened a week later, so they blamed it on a faulty starter and replaced it again. The car drove fine for 3 weeks or so, then had the same problem, when I took it back to them they said it was the ignition relay and replaced that. That was 4 weeks ago and yesterday my car wouldn't start again.
The one consistent part is that it typically won't start after I drive it for a short period (5 minutes), get out of it for a short period (5-10 minutes) and then get back in. It will usually start up after letting it sit for a while, but not always.
I would appreciate any thoughts on what could be causing all of these problems.
rideagiant
09-10-2009 07:56 AM
