1998 Volvo V70 2.4 turbo AWD
Old Jan 20, 2010 | 08:28 AM
ben watson's Avatar
Default 1998 Volvo V70 2.4 turbo AWD
Hi there people, Was wondering if anyone has had a problem with their V70 misfiring whenever it feels like it? Sometimes its fine and other times it will do it three or four times on a run? Changed plugs, Ht leads, coolant Temp sensor, Temp Stat, Fuel filter, Air filter. Had it plugged in but ther was no errors or error history on e.c.u so i dont know can anyone help? Also does anyone know the front tracking settings for a four wheel lazer tracking system? kind reguard Ben.
Old Jan 24, 2010 | 01:43 AM
gdog's Avatar
I didn't see cap/rotor in your list. Can I assume "Ht leads" stands for "high tension leads", aka spark plug wires?
Some more context would also be helpful; e.g. does it misfire under heavy load, feathered throttle, etc.
Old Jan 28, 2010 | 02:53 AM
ben watson's Avatar
Yeah i havent changed them as they weren't very old as i took them off the 850 before i had sold it and put them on the v70. Usually the hick up happens on slow torque accelerating not flooring it, it is very annoying. Also can a worn steering rack cause the steering to come out of track?
Old Feb 26, 2010 | 02:41 PM
aidyjreeve's Avatar
Default Missfire
I had this on mine, would miss fire stop and the engine management light would come on. I found that the positive lead to the battery was poorly connected and only giving 12 volts not the full 14 from the alternator, a new clamp sorted the problem and never had a miss fire in 4 years.
LarryNH914
Mar 5, 2018 12:11 AM
snsrgy611
Sep 14, 2015 12:55 PM
snsrgy611
Apr 10, 2009 11:31 PM
snsrgy611
Apr 6, 2009 07:08 PM
tcrossley
May 20, 2006 12:50 AM
